1998 Chrysler Neon sudden lack of power
108,000 MILES • 4 CYL • FWD • AUTOMATIC
RATTIEV
this has only just statred to happen but after the long journey me and my family took from the uk to france and back again my car developed a lack of power,could not get it above 2000 revs and 50 mph.... felt like a possilby coil pack break down. after letting the car cool down for a while it was ok .... then it started to happen again....check for blink codes and found code 37 but i can not see anything to do with this fault code would cause this problem...many thanks any suggestions????
Jun 22, 2010 at 8:41 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 22, 2010 at 8:44 AM
