1998 Chrysler Neon Running Rough!!!
140,000 MILES • 4 CYL • FWD • MANUAL
DAGENERAL666
our little neon is running rough it has little or no power going uphills checked the error codes it blinked twice saying that it might be the timing error code maybe skipped a tooth but it has little or no power sounds like only a few or a couple cylinders are running shakes a little while driving it mainly just sounds like 1 or 2 cylinders aren't firing checked spark plugs haven't checked injectors yet car seems to idle alright but still sounds like a couple cylinders aren't firing.
Dec 23, 2009 at 8:11 AM
JDL
  • 16,098 POSTS
welcome to the forum, what are the actual codes? How long since a tune-up? Do you have spark at all plugs? Use a gage and check fuel pressure.
Dec 23, 2009 at 8:22 AM
DAGENERAL666
im pretty sure the light blinked twice so that would be 11 right then i saw it was the timing on the error codes havent tested the plugs going to do that very soon.
Dec 24, 2009 at 11:20 AM
JDL
  • 16,098 POSTS
My info says, the mil method won't work on this vehicke, at the least, you need an obd11 code reader?
Dec 25, 2009 at 3:14 AM
