1996 Dodge Neon SPEEDOMETER
135,000 MILES • 4 CYL • FWD • AUTOMATIC
BOLO401
I replaced the cylinder head due snapped timing belt. car running ok for some months now, but speedometer sometimes work and sometimes not. Currently I am using my GPS for speed indicator. Pls advise possible solution. Thanks, BOLO
May 6, 2010 at 11:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle uses a Vehicle Speed Sensor to operate the speedometer. You most likely have a failing VSS which is on the tranny.
May 6, 2010 at 3:57 PM
