No electrical power
KOCOBOY
1999 Chrysler LHS, 104,000 miles, V-6, 3.6
Had the starter replaced one year ago.
At first it turned over once and then made loud clicking noises. I removed and cleaned the positive battery cable connection , tried to reach the negative terminal with wire brush but it's hard to get to. Now the car has absolutely no power at all even when I try to jumpstart it. Any ideas on why all power is now gone? Thanks so much for any advice, I'm having a hard time getting information online.
Oct 20, 2007 at 1:29 PM
BLACKOP555
  • 10,386 POSTS
clean the cables and try jumping the car. should fire right up. if you cant get hte cable off you might have to use a battery puller
Oct 20, 2007 at 1:46 PM
