Interior lamps on continually
DAN_T
Chrysler, LHS, 1994, 75,000 miles, 3.8L? V6
Interior lamps (dome lamps) on continually, will not turn off without removing fuse. Would a faulty timer create this problem? If so, where is it located?
Nov 28, 2007 at 4:22 PM
MVERICK
I have a 94 LHS with the same problem. Finally I went around and SLAMMED the doors as hard as I could and it worked. Until of course the next time I use the door (which one I haven't figured out yet so I just slam them all)....hope it helps
Dec 14, 2007 at 7:41 AM
MOPAR101
[quote:5dfa1a19bc="Dan_T"]Chrysler, LHS, 1994, 75,000 miles, 3.8L? V6
Interior lamps (dome lamps) on continually, will not turn off without removing fuse. Would a faulty timer create this problem? If so, where is it located?[/quote:5dfa1a19bc]
It sounds like you have a bad door switch.The switch is located on the pillar.I had to replace both side of my LHS,not a big job and they are not a pricey item.Hope this helps.
Dec 28, 2007 at 1:29 AM
