2002 Chrysler LHS Battery
132,000 MILES • 6 CYL • FWD • AUTOMATIC
MYDISTOUCH
How do I change the battery on a 2002 Chrysler LHS?
Jan 2, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
[quote:460131c3a8="Mydistouch"]Electrical problem
2002 Chrysler LHS 6 cyl Front Wheel Drive Automatic 132000 miles
How do I change the battery on a 2002 Chrysler LHS?[/quote:460131c3a8]
nothing special about it
Turn key off make sure every thing is off in car
Disconnect negative cable first and then the positive
isolate and set aside
remove hold down bolt s
if your car has a heater blanket remove it and set aside remove battery
when installing new battery reverse procedure
just install positive cable 1st then negative last
good luck
Jan 4, 2008 at 12:02 PM
