2001 Chrysler LHS transmission fluid low
10,400 MILES • 6 CYL • FWD • AUTOMATIC
DFHAWKINS
I just did a tranny service on the car, Chrysler LHS and put in 4 1/2 quarts of transmission fluid - like the book told me to. When I check the transmission dipstick- it reads low. do not want to overfill.
Had to have the gear shift cable replaced about 3 months ago, mechanic left a note to watch the transmission dipstick.
Any ideas on why it would read low? I can't seem to find the mechanic who worked on the car..
Feb 25, 2008 at 1:22 PM
BMRFIXIT
  • 19,053 POSTS
do you have a leak ?
add fluid use only ATF+3 or Chrysler tranny fluid
drive car around few min.
warm up the fluid check the dip stick and adjust
check in few day and if low
check for leaks
Mar 3, 2008 at 10:59 AM
