2001 Chrysler LHS key wont turn in ignition
JVAUGHN1121
Engine Mechanical problem
2001 Chrysler LHS 6 cyl Automatic 159000 miles
my key wont turn in the ignition. ive tried graphite powder and that didnt seem to have any affect. when i initially noticed the problem, i tried turning my steering wheel so now its locked up. i dont know if it is a tumbler inside the cylinder that is jammed or something more severe. possibly do i need a new lock cylinder? what else should i look for as a potential problem? any suggestions are much appreciated!!!
also - i might as well add that the remote start works and the car will still start, but obviously i need to turn the key in the ignition to go anywhere. but at least the car is capable of starting.
Feb 23, 2009 at 3:56 AM
  • 110,248 POSTS
If you have tried lubericating it and a different key, then the tumbler must be bad. The bad part is to replace it you need to remove the steering wheel and part of the steering column.
Mar 17, 2009 at 6:31 AM
