2001 Chrysler LHS fan only works with the key turned half w
198,632 MILES • 6 CYL • FWD • AUTOMATIC
SQUAKY0
When the car is started the fan shuts off , the temp control digital reader goes dim and then I here a click and the ABS and TRAC light turns on!
Dec 4, 2009 at 8:56 AM
CARADIODOC
  • 34,413 POSTS
Suspect burned contacts inside the ignition switch.
Dec 23, 2009 at 3:32 PM
