Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
LHS
Electrical
Ignition Switch
Key
2001 Chrysler LHS fan only works with the key turned half w
2001 CHRYSLER LHS
198,632 MILES • 6 CYL • FWD • AUTOMATIC
SQUAKY0
MEMBER
1 POST
When the car is started the fan shuts off , the temp control digital reader goes dim and then I here a click and the ABS and TRAC light turns on!
Dec 4, 2009 at 8:56 AM
CARADIODOC
Experienced Mechanic
Suspect burned contacts inside the ignition switch.
Dec 23, 2009 at 3:32 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
