2000 Chrysler LHS starter
JWILKE
Engine Mechanical problem
2000 Chrysler LHS 4 cyl Two Wheel Drive Automatic
cant get starter out all bolt are off
Apr 28, 2010 at 1:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
2.7L Remove or disconnect the following: Negative battery cable from the remote ground post Battery feed and posi-lock connectors Nuts from the catalyst support bracket and mount Starter heat shield 3 starter-to-engine/transaxle bolts Now remove starter by rotating it toward the engine and sliding it rearward between the catalyst and the engine mount 3.5L Remove or disconnect the following: Negative battery cable from the remote ground post Starter-to-engine/transaxle nut and bolts Positive battery feed wire from the starter Starter and position it to gain access to the posi-lock connector Place a support under the engine and slightly relieve the pressure from the left engine mount. Remove the 3 left engine mount-to-engine bolts. Slightly, raise the engine to provide more room. Remove the starter by sliding it rearward between the catalyst and the engine mount. Remove the posi-lock connector.
https://images.2carpros.com/forum/automotive_pictures/261618_1_159.jpg
Apr 28, 2010 at 1:40 PM
