is there a sequence in changing the plugs and should the positive battery cable be disconnected
Dec 20, 2007 at 8:20 AM
BMRFIXIT
✓Experienced Mechanic
[quote:a29f9cf1fa="bleeson1"]Electrical problem
2000 Chrysler LHS 6 cyl Two Wheel Drive Automatic 140000 miles
is there a sequence in changing the plugs and should the positive battery cable be disconnected[/quote:a29f9cf1fa]
change it in the order you like
and no need to disconnect battery
