2000 Chrysler LHS Radiator fan assembly
2000 CHRYSLER LHS
112,000 MILES • 6 CYL • FWD • AUTOMATIC
HENDERSON4028
I have a question my fan assembly well the passengerside has burned out again. This is the third assembly in five months. I need to see what could be causing the fans to burn out or am i just buying defective parts. I've smelled a burning smell for awhile and im wondering if i need to replace the ac clutch or the whole compressor or am i having a condenser problem it is only the rightside fan that has burned out on all three.
Oct 7, 2008 at 9:28 AM
2CARPRO JACK
  • 11,533 POSTS
Are you using Chrysler parts? If not I would start there. Be sure grounds are good. Use a meter to measure resistance to ground from the motor plug, this can cause the motors to overheat and shorten the life
Oct 8, 2008 at 5:29 AM
