2000 Chrysler LHS problem in service bulletin
2000 CHRYSLER LHS
73,000 MILES • 6 CYL • FWD • AUTOMATIC
CYNDID
A service bulletin came out stating 38 of 68: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Date: MAR 2000
A CONDITION MAY EXIST WHERE A LOW TONE GROWL SOUND CAN BE HEARD COMING FROM THE ENGINE FOLLOWING A COLD START WHILE IN DRIVE OR REVERSE WITH ENGINE RPM BETWEEN 1000 AND 1300 RPM. *TT
I am having this problem, what needs to be done, any idea of cost? Thank you
Jan 15, 2009 at 1:25 AM
RACEFAN966
  • 5,029 POSTS
Ok what is the bulletin number that youare refering to? What V6 engine do you have? Get back to me and I will look into it further.
Jan 15, 2009 at 2:33 AM
CYNDID
Engine: 3.5L
SERVICE BULLETIN:070100 NHTSA ITEM NUMBER:610622
MFG Bulletin Date: 20000331
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Bulletin Summary: A CONDITION MAY EXIST WHERE A LOW TONE GROWL SOUND CAN BE HEARD COMING FROM THE ENGINE FOLLOWING A COLD START WHILE IN DRIVE OR REVERSE WITH ENGINE RPM BETWEEN 1000 AND 1300 RPM. *TT
Date added to datbase: 20000508
Jan 15, 2009 at 3:08 AM
RACEFAN966
  • 5,029 POSTS
Yes I found it and it has to do with belt tension being to tight. They say to retension the belt so that it is only at 120 to 140 lbs of belt tension with a belt tension tool. Hope this answers your question. Thanks.
Jan 16, 2009 at 2:39 AM
