2000 Chrysler LHS Power Steering problem
134,500 MILES • 6 CYL • 2WD • AUTOMATIC
GREISEN
My 2000 LHS has power steering turning right but not left. Is this indicitive of a pump problem or a rack problem?
Aug 15, 2009 at 9:15 AM
CAPTAINRODGER
I have the exact same problem, have you had any luck with a repair?
Sep 15, 2009 at 12:46 PM
AKLEWIS100
  • 5 POSTS
the problem is the rack and pinion sorry and its not a cheap fix chrysler tends to have a rack and pinion problem
Feb 15, 2010 at 9:25 AM
RICHIE333
  • 13 POSTS
I had the exact same problem. I removed the steering gear (no small task) and had it rebuilt by an auto parts place in Burbank, CA for $115. And I'm sure that it would have worked perfectly, if I hadn't put in the wrong fluid. Every expert I asked gave me a different answer (including Chrysler dealership parts managers).
Do NOT use ATF+3 or +4 (Automatic Transmission Fluid).
Do NOT use Dextron/Mercon, or anything with Teflon in it.
Do NOT use just any common market Power Steering Fluid.
Only USE Chrysler's MOPAR Power Steering Fluid.
It's like $15 a quart, at any Chrysler dealership's parts department.
Also, there is is distinct advantage to having your original rack rebuilt vs. purchasing a new (or newly rebuilt) part — first, the $$$ savings, and second, it fits back in with no surprises.
Apr 8, 2010 at 10:33 AM
RICHIE333
  • 13 POSTS
Well, almost no surprises. I still have zero power assist, even though I am using the correct fluid — Chrysler's MOPAR Power Steering Fluid.
I suspect it might be a clogged filter, or a bad pump.
(I have a similar thread/question running in this forum, and have asked for help there....)
Apr 9, 2010 at 8:04 AM
