steers normally to the right very hard to steer to the left
Jun 29, 2009 at 12:28 PM
✓Experienced Mechanic
It sounds like the rack and pinion is going bad. THere are bushings that wear and after they get so bad, the steering will do what you described. That is what I would check. Check to see if it's leaking where the inner tie rods attach.
