2000 Chrysler LHS hard steer one way
2000 CHRYSLER LHS
60,000 MILES • 6 CYL • FWD • AUTOMATIC
DP32301
steers normally to the right very hard to steer to the left
Jun 29, 2009 at 12:28 PM
  • 110,240 POSTS
It sounds like the rack and pinion is going bad. THere are bushings that wear and after they get so bad, the steering will do what you described. That is what I would check. Check to see if it's leaking where the inner tie rods attach.
Jul 23, 2009 at 3:07 PM
