2000 Chrysler LHS FRONT AND BACK PASSENGER LOCKS
2000 CHRYSLER LHS
114,552 MILES • 6 CYL • 2WD • AUTOMATIC
ROLON1980
The front and back passenger locks make a jammed noise when I press the unlock button and they have to be manually unlocked from the inside in order to get out or in. The front passenger door inside handle will not open the door it seems to not have any suspension like the driver side.
Feb 16, 2010 at 1:16 PM
CARADIODOC
  • 34,381 POSTS
If the locks are making a buzzing noise, the armatures are broken loose from the shafts of the motors. The lock motors or latch assemblies will need to be replaced.
Sounds like the linkage is disconnected to the right front door handle.
caradiodoc
Feb 25, 2010 at 12:48 AM
