2000 Chrysler LHS Driver side window glass
DO25BUBBA
2000 Chrysler LHS
Hello, One of my daughters girlfriends, has a 2000 Chrysler LHS, and the driver side window, was busted out. I told her parents that I may be able to replace if for her. I am going to do the calling around to find a glass, and install it.
Is this hard to do? Is the glass installed with rivots, or does it sit in brackets and the brackeds are bolted to the window tracks......I am pretty mechanically inclined, and think I can do this. Could you send me in the right direction,
She is 16, just got her license and doesnt have alot of money.....
Can you get me going.
Thanks, Ray
Apr 19, 2009 at 12:52 PM
CARADIODOC
  • 34,405 POSTS
No rivets, just nuts. You'll have to roll the window down about 6". Loosen the nuts holding the glass, then slide the bracket back to remove the nuts. Tilt the glass to remove it from the channels and lift it out.
caradiodoc
Apr 20, 2009 at 7:04 PM
