2000 Chrysler LHS Brake pads and rotors
2000 CHRYSLER LHS
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
IMATEIU
I would like to find out how do I know when the pads and rotors are bad. What should I look for?
Feb 5, 2009 at 8:56 AM
  • 110,244 POSTS
The pads should be replaced when they get below 2/32 inch of pad left. As far as the rotors, if they are warped beyond cutting or they are worn below minimum specifications of thickness (stamped on rotor) they need replaced.
Mar 17, 2009 at 6:37 AM
