2000 Chrysler LHS
JR101
Brakes problem
2000 Chrysler LHS Front Wheel Drive
HOW TO REPLACE ROTAR
Mar 13, 2010 at 3:00 PM
CH112063
  • 1,320 POSTS
If you mean replacing the front brake rotors it's pretty easy, we try to replace them in pairs so there is no chance of any brake pull. You remove the wheel, unbolt and remove the caliper, there may be clips, you can snip them off with wire cutters or needlenose pliers. Then reverse this. You really should replace the pads also unless they have already been done lately, ok?
Mar 18, 2010 at 4:07 PM
