1999 Chrysler LHS Starter won't engage every time
1999 CHRYSLER LHS
165,000 MILES • 6 CYL • FWD • AUTOMATIC
RORY_SMALL
My car has gotten steadily worse over the last 4 months in regards to starting. I have a fully charged battery and everything lights up fully, but when I turn the ignition, all I hear is a loud, audible CLICK. Takes about 10-15 tries to get it to start turning over (sometimes it won't fully start over).
I was going to replace the starter (and the selenoid attached to the starter), but the manual says I may have to loosen the engine mounts to get the starter out??
My question is A) am I on the right path and B) do I really have to loosen the engine mounts to remove the starter on this vehicle??
Thanks for your help!
Jan 4, 2008 at 5:03 AM
BMRFIXIT
  • 19,053 POSTS
[quote:154d8591b7="Rory_Small"]Engine problem
1999 Chrysler LHS 6 cyl Front Wheel Drive Automatic 165000 miles
Thanks for your help![/quote:154d8591b7]
Most manual will speak in general term form
it sounds to me that you need to replace the starter solenoid is part of the starter
need more inf. let me know
Jan 4, 2008 at 5:40 AM
