1999 Chrysler LHS power steering loss in one direction
CAPTAINRODGER
Steering problem
1999 Chrysler LHS 6 cyl Front Wheel Drive Automatic 103k miles
I have 1999 Chrysler LHS, everything was fine when I drove home, the next morning, no power steering turning left, turning right is fine. I'm told I need to change the rack and pinion. Is there any type of check valve that can be changed instead of changing the whole thing?
Sep 15, 2009 at 12:25 PM
  • 110,248 POSTS
Chances are the bushings are bad in the rack and pinion. This is a common sympton for that problem.
Sep 21, 2009 at 3:39 AM
