1999 Chrysler LHS CAR WON'T HEAT UP
1999 CHRYSLER LHS
19,000 MILES • V8 • 2WD • AUTOMATIC
PCAUTO
CHANGED RADIATOR (NEW) THERMOSTAT, SERPTINE BELT AND WATER PUMP. CAR HEATS UP TO NORMAL, BUT DOEN'T THROW THE HEAT IT SHOULD. THE OP RADIATOR HOSES GETS HOT BUT THE BOTTOM STAYS COLD.
Feb 13, 2010 at 5:20 AM
CARADIODOC
  • 34,381 POSTS
Sounds like a plugged heater core. They can usually be cleared with a garden hose. Remove the heater hoses from the engine and run water through them both ways until it flows freely.
caradiodoc
Feb 14, 2010 at 7:18 PM
