battery location
89,000 MILES • 6 CYL • FWD • AUTOMATIC
MSSST20
how do you replace the battery ?
Jan 3, 2009 at 8:19 AM
The battery on this vehicle is under the air cleaner housing in the fender and once you remove the air cleaner housing you will see it.
There is a remote negative terminal that if you follow down you will see the battery location.
Here is a guide that helps with this:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Below you will find the info from the manual that will give the remaining details needed to perform this.
Please let us know what other questions you have. Thanks
Mar 5, 2022 at 8:23 AM
