Electrical problem
1999 Chrysler LHS 95000 miles
I have a 99 Chrysler LHS. I have had the car for a little over a month and had no problems until now. The alternator went bad. Now, after replacing the alternator, it will not charge the battery. Took it back out and it tested fine. However, the alternator gets extremely hot after running the car for only a few minutes. I have also replaced the PCM with one from another used car. Still the same issue: Not charging and alternator gets extremely hot.
Jun 22, 2009 at 1:41 PM
