1999 Chrysler LHS
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
JTCYPHERS
I have a 99' Chrysler LHS and the power windows stopped working out of the blue. None of the windows will roll down and none of the fuses are blown. It can't be that all the motors have gone bad at once. The windows won't move or act like they can. Also when you press the button to roll down a window the lights on the driver side door shut off.
Mar 14, 2010 at 6:06 PM
CH112063
  • 1,320 POSTS
Even if just your drivers door window switch became disconnected(common problem) or this drivers switch is bad none will work, the way it is wired, you have total control with a lock that keeps anyone else from using their own window. Try checking the drivers power window switch. ok, good luck
Mar 18, 2010 at 3:42 PM
