1999 Chrysler LHS
1999 CHRYSLER LHS
139,000 MILES • 6 CYL • FWD • AUTOMATIC
BRANDO_487
I am having problems starting my car. When i start it, it has a problem idleing but when i put it in gear i drive it is fine but when i stop and put it into park and let it idle it is fine. It dose it every 30-50 miles i have changed the spark plugs. I think it might be the fuel filter or fuel pump but i am not sure what it is. I also added fuel cleaner the last time i filled up with gas.
Mar 25, 2010 at 7:10 PM
LEGITIMATE007
  • 5,121 POSTS
I think your problem may be the idle air control valve, you may also want to clean the throttle body that will cause some unstable idleing and accelaration probs.
Mar 28, 2010 at 4:55 AM
LEGITIMATE007
  • 5,121 POSTS
