1997 Chrysler LHS Sloppy steering
HELP296
  • 5 POSTS
Steering problem
1997 Chrysler LHS
When I turn the steering wheel from side to side there is a clicking or popping sound. Found a worn stabilizer bar link that was bad on the pass. side replaced it and its a little better, but while driving you can turn the wheel from 11:00 to 1:00 before it actually "catches" and turns the tires. I checked the steering gear and it moves a little fom side to side. Checked the bolts that hold it on and there tight. Any ideas? Thanks.
Nov 18, 2009 at 4:04 AM
  • 110,248 POSTS
I believe you have a rack and pinion, correct? Have you checked tie rods? If they are tight and I am correct about the rack and pinion, chances are the play is in the rack itself.
Nov 26, 2009 at 3:54 PM
CARADIODOC
  • 34,407 POSTS
You found the cause. The rack should not be moving side to side. Instead of bolting it directly to the body, it is sandwiched between two metal plates on each end that are riveted together. Rubber isolators are between the brackets and the rack housing. Check to see if the movement is taking place between the housing and brackets. There was a service bulletin related to those brackets causing a squeaking noise, but I think that was on earlier models.
You can also have someone move the steering wheel back and forth a few inches while you inspect the steering shaft for looseness. In particular, look at the universal joint. Jacobandnickolas is right about play in the rack itself, but it's relatively uncommon. When it does occur, it's caused by a worn spool valve / input shaft and is accompanied by fluid leakage from the shaft area. It can be hard to diagnose because it's buried inside a tunnel formed in the firewall. And yes, don't overlook the outer tie rod ends. A lot of shops will perform a free steering and suspension inspection while doing other service.
caradiodoc
Nov 28, 2009 at 3:57 PM
