1997 Chrysler LHS resetting clock
139,000 MILES • 6 CYL • 2WD • AUTOMATIC
NLHAND31
How do I reset the clock on a 1997 LHS?
Apr 21, 2009 at 5:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
This information can be found in the owner's manual or by contacting your local Chrysler dealer. However, most radio clocks can be set by holding in one button (usually a 'SET') button and then choosing up and down to set the hour and minutes time. Hope this helps..
Thanks for using 2CarPros.com!
Apr 27, 2009 at 11:49 AM
CARADIODOC
  • 34,413 POSTS
If you haven't figured it out yet, holler back with a description of your radio. The higher end cd players have a minute and an hour button. They're real small, on the right side of the display crystal. You press them with a pen tip.
caradiodoc
Apr 29, 2009 at 5:31 PM
