1997 Chrysler LHS only clicking
1997 CHRYSLER LHS
ROGERS.2785
Electrical problem
1997 Chrysler LHS 6 cyl Front Wheel Drive Automatic 144k miles
my chrysler died out while i tried to get unstuck from a pile of snow i tried to start it back up it reved for a second then only clicking since then i've tried charging the battery and also to replace it no luck still clicking checked 2 locatable fuse relays found no blown fuses also right after it clicks it shuts off all the power for about 5 min. then power comes back on any clue?
Feb 7, 2009 at 12:08 AM
  • 110,244 POSTS
My guess is one of two things. First, check all battery connections from the battery and to where they are going. My guess is something is loose or not making a good connection.
If everything is good, have a helper turn the key to the start position while you check for 12 volts at the smaller wire on the starter.
Let me know what you find.
Mar 17, 2009 at 6:36 AM
