1997 Chrysler LHS I have no brakes
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
EVELYN26
I HAVE NO BRAKES AND BEFORE THE BRAKES WERE GONE I WAS HEARING A LOUD SCRAPING NOISE. MY ANTI LOCK BRAKES DOES NOT WORK EITHER. I ALSO HAVE PUT BRAKE FLUID IN THERE BECAUSE IT LOOKS AS IF IT IS RUNNING OUT SOME KIND OF WAY.
Dec 15, 2008 at 1:56 PM
  • 110,248 POSTS
Hi:
The screaching was most likely the shoes or pad are bad and you were hearing a metal to metal sound. As far as the brake fluid, can you see any wet spots where you park or on the backs of the tires...
Finally, when you push the brake pedal, does it go to the floor?
Let me know
Dec 19, 2008 at 8:16 AM
