Recently my 3.5 engine idle speed started to increase. At first it went up a few hundred RPM, but lately has increased to 2200 RPM. At a cold start it will idle at 1500. Within 5 minutes the RPM will rise to 2200. I checked vacuum lines, cleaned the idle control motor, nothing I do seems to effect it. The check engine light comes on and then after a day or two it will go out for a day. I strongly suspect that too much air is getting into the manifold. I removed the air cleaner and blocked airflow to the plenum and still there was no change in RPM's. What am I missing?
Feb 13, 2008 at 4:13 AM
