1997 Chrysler LHS HELP ME
JOEY3030
Engine Performance problem
1997 Chrysler LHS 6 cyl Front Wheel Drive Automatic ?????? miles
MY CAR IS RUNNING LEAN AND TWO RICH I REPLACED EVERTHING FROM IAC TO MAPPS MY CAR IS RUNNING BELOW 1OOO ITS CRAZY I UNPUGG THE MAPSS SENCER ITS STILL TO RICH BUT NOT IDEL LOW I KNOW ABOUT THE RECALLS I THING A WIRE GROUNDING OUT
Feb 24, 2008 at 12:12 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
Feb 24, 2008 at 12:40 AM
