1997 Chrysler LHS Fuel problems
1997 CHRYSLER LHS
187,701 MILES • 4 CYL • FWD • AUTOMATIC
SLIMSHORTY
My car ran out of gas, so I put a half a tank of gas in the car and it still wont start could I need a whole new fuel pump? or is there a possibility that there is an emergency shut off switch?
Aug 20, 2009 at 2:51 PM
Best way to find out is to check the fuel pressure with gauge if its producing pressure. could be fried, clogged-up intank screen and a fuel filter
Aug 20, 2009 at 3:02 PM
There's no fuel cut off switch like FORD products-Do you hear the fuel pump come on when you turn key to run-if so check the pressure if not check the fuel pump fuse and fuel pump relay
Aug 20, 2009 at 3:40 PM
