1996 Chrysler LHS will not spark no cobes has spark and fue
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAZEYDEZEY
  • 18 POSTS
Hey about 1 year ago I did cam seals waterpump and main seal. last night i come home next day i try to satrt, cranks but wont start. pressure is 20 with first turn of key 2nd turn 49 key again 50 49. Has spark, throws no codes, timing belt in tact,anti freeze good to -20. battery connections have power. no engine light. What could it be im puzzled thanks
Jan 1, 2010 at 9:35 AM
  • 75,988 POSTS
Sounds like a fuel pump problem if you have to play with the key 3X to build pressure-should be up to specs with 1-turn of the key also check for injection pulses-
Jan 1, 2010 at 9:39 AM
