Strong Gas smell from car in garage/after?
1996 CHRYSLER LHS
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
CFEFFECTS
My car has a very strong gas smell coming from the exterior after i had pulled into my garage. I never noticed any gas smell on the drive home, coming from the inside of the car. But immediatedly after I got out and closed the garage door...it smelled like a huge fuel spill...and permiated into my house. I had to park it outside. I also did not see any fuel spillage. (if that's a word)
This has happend once before but the smell was also inside the car. (I forget what was fixed at that time).....
What is it this time??? A fuel pump going south? I have not experienced any sluggishness from acceleration or such. I'm paranoid to drive it to work tomorrow. Should we just tow it to our shop or can it be driven? It IS unsafe to drive when one smells fuel correct?
Sep 10, 2009 at 2:14 PM
  • 110,244 POSTS
Any time there is a fuel leak, there is danger of fire. Where did you see the leak from the front or rear? Also, a bad fuel pump won't cause a leak so don't let anyone talk you into that.
Sep 21, 2009 at 3:48 AM
