1996 Chrysler LHS no heat
DANAG1
  • 91 POSTS
Heater problem
1996 Chrysler LHS
Have a 1996 LHS, checked the thermostat,. both hoses that goes into the heater core are hot, but no heat. What can be the problem?
Oct 6, 2009 at 12:50 PM
CH112063
  • 1,320 POSTS
Yes, maybe the temp. blend door is not moving to the correct position in thr heater/ac unit. It may be electric or vacuum operated, sometimes a cable also.
It is inside behind your inst. panel.Joe
Oct 7, 2009 at 12:30 PM
DANAG1
  • 91 POSTS
behind instrument panel, where the control of heat/ac is? how can I get to that door? .. any idea if this door is controled by some fuse/relay which can be located in the fuse panel?!?
Oct 7, 2009 at 12:56 PM
CH112063
  • 1,320 POSTS
If you check there may be a fuse out. But I think there is two types. ! has a small motor to move the blend door from hot to cold. 2. Has a cable right behind the climate control panel. The cable goes to the top of the door, either one is on the top of the heater a/c unit. A black box that holds all the doors, evaporator and heater core. The heat blows out of it on its bottom. It is quite a bit of disassembly to remove. If you take the control panel out, you may see something through that area and if it has a cable you will see that also. If you have an electronic you just set the temperature in degrees, if cable there is a slide attached to it. ok Joe The door is in the unit and is serviced with the unit out and apart. about a 6 hour job. Joe
Oct 8, 2009 at 9:43 AM
