1996 Chrysler LHS Heater Core
1996 CHRYSLER LHS
130,000 MILES • 6 CYL • FWD • AUTOMATIC
SUGARLANGE
Heater\defrost is blowing cold air....car still overheats after installation of new thermostat. Could it be possible that the heater core is not working and if so...could this cause my car to overheat? And with my make of car..where is the heater core located...behind the firewall? Thanks
Jan 13, 2010 at 1:16 AM
CARADIODOC
  • 34,383 POSTS
When the engine is warmed up, feel the two heater hoses. If they're too hot to hold onto for very long, (normal), suspect a problem with the temperature door or actuator, or more likely, the heater computer that controls it.
If the hoses are cool, suspect a plugged heater core. They can usually be back flushed with a garden hose.
For engine overheating, if this does not occur at highway speeds, suspect a radiator fan not turning on.
If both symptoms started at the same time, the thermostat was not the problem. During overheating, the air from the heater would have been too hot, not too cold. The two symptoms together suggest coolant is not circulating. Two possible causes are water pump problems or air pockets from a leaking head gasket. Bubbling in the overflow reservoir is a good sign of a head gasket problem. Your mechanic will check at the reservoir with a glass tube filled with a special dark blue liquid that will turn bright yellow if combustion gases are present.
caradiodoc
Jan 17, 2010 at 12:02 AM
