1996 Chrysler LHS Coolant Problem
AWOZNICK
1996 Chrysler LHS
My engine coolant reservoir is dumping coolant out of the dump line resulting in low fluid level and overheating as a result. What could be the cause for this?
Aug 16, 2009 at 4:28 AM
WAUGIE
[quote:d20851ac53="awoznick"]1996 Chrysler LHS
My engine coolant reservoir is dumping coolant out of the dump line resulting in low fluid level and overheating as a result. What could be the cause for this?[/quote:d20851ac53]
I had a similar problem. Fixed by replacing the reservoir cap with a new one. Also, be sure to bleed your cooling system (bleeder is on the thermostat housing).
Aug 20, 2009 at 8:47 AM
