1996 Chrysler LHS Coolant Problem
1996 CHRYSLER LHS
AWOZNICK
1996 Chrysler LHS
My engine coolant reservoir is dumping coolant out of the dump line resulting in low fluid level and overheating as a result. What could be the cause for this?
Aug 16, 2009 at 4:28 AM
WAUGIE
[quote:d20851ac53="awoznick"]1996 Chrysler LHS
My engine coolant reservoir is dumping coolant out of the dump line resulting in low fluid level and overheating as a result. What could be the cause for this?[/quote:d20851ac53]
I had a similar problem. Fixed by replacing the reservoir cap with a new one. Also, be sure to bleed your cooling system (bleeder is on the thermostat housing).
Aug 20, 2009 at 8:47 AM
