1996 Chrysler LHS
JESUSJUICE420
  • 1996 CHRYSLER LHS
Electrical problem
1996 Chrysler LHS 6 cyl Front Wheel Drive Automatic
my high speed fan relay, low speed fan relay, ac compressor Clutch EVAP Purge Solinoid and the manafold tuning valve have shorts and the only thing the same is splice 124 and thats not the problem
Monday, April 20th, 2009 AT 4:11 PM
CARADIODOC
  • 33,916 POSTS
So what is the problem? Am I safe in assuming fuse # 20 is blowing? And does it blow right away or while you're driving?
If it blows right away, unplug the various items, replace the fuse, then plug in one item at a time until the fuse blows again.
Relay coils draw very little current. If unplugging one of them solves the problem, expect to find excessive corrosion inside, but I find it hard to believe it could draw 20 amps. My guess for the most likely culprit is a grounded wire in the harness. The next would be a shorted solenoid. Still not common, but try unplugging the EGR solenoid, charcoal canister purge solenoid, or the manifold tuning valve solenoid.
Holler back with more details if you don't find the problem.
Caradiodoc
Tuesday, April 21st, 2009 AT 1:52 AM
