water pump removal
ACAILL00
i need to know how to remove the water pump from my LHS. I don't know which pulley to loosen to relieve the tension on the belts. or how to loosen the pulleys. and once i remove the pulleys and the metal shield that is between the pulleys and the timing belt then i don't know if I will also have to remove the timing belt and risk jumping the time. finally i believe that i can install the water pump, but some direction of reassembly regarding the tension on the pulleys would be helpful also. thank you.
Sep 14, 2008 at 1:02 PM
KHLOW2008
  • 41,812 POSTS
Hi acaill00, I do not know which version engine you have so I am attaching 2 different diagrams. Unloosen the locking nut on the pulley with adjusting bolts and unloosen the adjusting bolts to release the tension.
https://images.2carpros.com/forum/automotive_pictures/192750_Belt95Chrysler01_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_Belt95Chrysler02_1.jpg
To replace the water pump, you need to remove the timing belt. Removal 1. Disconnect negative battery cable from jumper terminal. Remove upper radiator crossmember (may also be referred to as the engine compartment support). Remove electric cooling fan module with fans. 2. Remove accessory drive belts. Hold crankshaft damper stationary while removing center bolt.
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt95ChryslerLHS_1.jpg
Use gear puller to remove crankshaft damper. Remove the A/C belt guide/lift bracket. 3. Remove lower timing belt cover. Remove stamped steel (right side) timing belt cover. DO NOT remove the sealer on the stamped steel cover, as it is reusable. 4. Remove cast (left side) timing belt cover. If reusing old timing belt, mark belt direction of rotation for reinstallation. 5. Rotate crankshaft to align crankshaft sprocket timing mark with TDC mark on oil pump housing. Align camshaft sprockets with marks on rear covers.
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt95ChryslerLHS02_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_TimingBelt95ChryslerLHS03_1.jpg
6. Remove timing belt tensioner. Store with plunger facing up. Remove timing belt. CAUTION: The following procedure can only be used if camshaft sprockets have NOT been loosened or removed. If camshaft sprockets have been removed, special tools and timing procedure are required. CAUTION: Align camshaft sprockets between marks on rear belt covers before removing timing belt, or damage to valves and pistons may occur. CAUTION: When aligning timing marks, always rotate engine by turning crankshaft. Failure to do so will result in valve and/or piston damage. CAUTION: When timing belt tensioner is removed from engine, always store tensioner with plunger facing up. Page 1 of 1 TIMING BELT REPLACEMENT - 3.2L & 3.5L -1995 Chrysler LHS 9/15/2008
Sep 15, 2008 at 12:26 AM
ACAILL00
this is exactly the diagrams i was looking for, thank you so much. i am very impressed with your site and will use it for all future questions, thank you again!
Sep 15, 2008 at 8:07 AM
KHLOW2008
  • 41,812 POSTS
You are welcomed and all these are courtesy of Mitchell1 and Chrysler :)
Sep 15, 2008 at 11:58 PM
ACAILL00
my new problem involves the harmonic balancer, which i need to remove somehow to get to the water pump etc. I have bought the puller for the harmonic balancer, but i cannot break it loose to be able to apply the puller, any suggestions or hints? thanks again!
Sep 22, 2008 at 3:59 AM
KHLOW2008
  • 41,812 POSTS
Hi acaill00,
I don't see any harmonic balancer in the diagram.
Sep 23, 2008 at 3:34 AM
ACAILL00
sorry, i am a girl, my husband called it the harmonic balancer, and i suppose it is actually the crankshaft damper.
Sep 23, 2008 at 4:05 AM
KHLOW2008
  • 41,812 POSTS
Hi acaill00,
If you have an impact wrench, it would not be a problem.
You need something to hold the damper while unloosening the bolt. Try your local Autozone, I believe they have a type of bar that is used for holding pulleys and you can rent it.
You can fabricate your own use an old belt seated in the pulley and using a piece of wood to hold while you turn the pulley to lock the belt and proceed with removal of the bolt.
I have seen people using the starter to crank it loose.
Sep 24, 2008 at 3:00 AM
MàTTHEW V. REICH
I the the same on a 94 3.5l v6 automatic Christler LHS? Meaning does the timing belt need to come off?
I overheated today, remove the thermostat because water was not circulating and building up lots of pressure on the Top Radiator hose...
No sure if it's the pump or the radiator is clogged.
Does the same without the thermostat and over heats in an instant. Thanks for the help in advance!!!!!
Not much on 94 LHS water pumps online
Dec 12, 2019 at 2:10 AM
  • 55,616 POSTS
It sounds like the water pump is bad are you trying to remove it? Here is a guide to help us see whats going on.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response. Please run down this guide and report back.
Dec 12, 2019 at 3:17 AM
