starts but dies
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ALBY
my car starts right up but dies. If I keep my foot on the gas it will stay running but not smooth. I've replaced the cam sensor, crank sensor and fuel pump.
I still have the same problem. Could it be the TPS?
Nov 25, 2009 at 9:49 AM
  • 110,248 POSTS
This sounds like a vacuum leak or the IAC valve needs to be replaced here are three guides I need you to go over.
and
https://www.2carpros.com/articles/stall-at-idle
and
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Please run down these guides and report back
Cheers
Nov 26, 2009 at 3:51 PM
ALBY
I've checked for vacuum leaks. The check engine light comes on. code 77 speed control Relay circuit. I was told that was nothing to do with my problem but I checked relay and it is fine. So I replaced ht IAC and the problem is fixed! I love this site.
Nov 26, 2009 at 11:24 PM
  • 110,248 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers Joe
Nov 27, 2009 at 9:27 AM
