1995 Chrysler LHS no heat and over heats
1995 CHRYSLER LHS
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
RYHNO74
i just bought this lhs and the heat blew cold i replaced thermostat still no warm heat and car overheats to what ive seen theres no leakage anywhere
Dec 1, 2008 at 10:10 AM
Overheating
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Dec 1, 2008 at 10:26 AM
