1995 Chrysler LHS Car runs rough when in gear
1995 CHRYSLER LHS
JBLANK
Engine Performance problem
1995 Chrysler LHS 6 cyl Two Wheel Drive Automatic 160k miles
I just got this car. It's in pretty good shape but when I put it in gear it runs rough and wants to quit. In park or neutral it runs good. There does not seem to be any misses in the motor and the engine rev's well. I changed the plugs and checked the wires. I also replaced the vacuum hoses that were worn
any idea's
Thanks
Jim
Aug 6, 2009 at 8:56 AM
JDL
  • 16,098 POSTS
Hello, how does it act at highway speed? Any codes?
https://images.2carpros.com/forum/automotive_pictures/170934_trouble_codes_mil_1.jpg
The above info is how to access some codes.
Aug 6, 2009 at 9:21 AM
JBLANK
I checked the codes and it reported 12 55
Thanks Again
Aug 6, 2009 at 9:43 AM
JDL
  • 16,098 POSTS
The codes didn't show anything. Code 12 means the battery has been disconnected at some point in the past. Code 55 is end of message. Is the idle speed too low in drive? If you open the throttle does the problem go away?
Aug 7, 2009 at 12:44 AM
JBLANK
The engine runs a steady 800 rpm in park. In gear it runs about 600-700 rpm
Aug 7, 2009 at 7:18 AM
JDL
  • 16,098 POSTS
What is the litre size of your engine? It's not unusual for the rpms to drop some when you put a load on the engine. In park there is not much load.
Aug 7, 2009 at 9:28 AM
JBLANK
The engine is a 3.5 v6
Aug 7, 2009 at 11:06 AM
JDL
  • 16,098 POSTS
Hi, other than general maintenance and the basics of fuel-- air and spark, I'd have to put a scanner on it, to look at live engine data, maybe then I would have a direction. Right now, I don't have a direction.
Aug 9, 2009 at 3:08 AM
