1995 Chrysler LHS brake light bulbs
1995 CHRYSLER LHS
95,000 MILES • 6 CYL • FWD • AUTOMATIC
CARUSO
Sounds simple - the brake lights dont light up. I want to check the bulbs but acces is not so obvious on this car. There are panels covering the entire area inside the trunk with no clear way to remove them. help me, please
Nov 14, 2008 at 4:08 AM
ZACKMAN
  • 4,202 POSTS
Those panels are attached by many plastic tabs. You have to remove those tabs in order to access the taillight. Flat head screw driver works, but you ruin those precious tabs. The best way to remove those tabs is by using panel removal tool, such as
https://images.2carpros.com/forum/automotive_pictures/55316_Panel_Tool_648544_1.jpg
Once the panels are out of the way, I think there are three black screw tabs that you have to remove, and taillight should come.
Nov 14, 2008 at 2:31 PM
