1994 Chrysler LHS white smoke
1994 CHRYSLER LHS
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
AKLEWIS100
  • 5 POSTS
i have white smoking coming out my exhaust i have a leak in the trans line that goes to the coolant so could the fluid be getting in o the exhaust that way. i checked the oil and i checked the oil cap and it is not milky and the cap shows no condensation
Feb 15, 2010 at 8:14 AM
  • 110,244 POSTS
It sounds like the trans cooling line is leaking. It goes to the radiator. That doesn't sound like the problem. If you have white smoke from the exhaust, that usually indicates there is coolant getting into the combustion chamber. If I had to guess, I would say you have a head gasket leaking. You could perform a compression test to see if one of the cylenders is low on compression.
Mar 5, 2010 at 2:09 PM
