Engine Cooling problem
1994 Chrysler LHS 6 cyl Two Wheel Drive Automatic 160K miles
1994 lhs overheating, it started after an oil/water pump/thermostat/ change 2 months ago. since then i have had to constantly add water (coolant would have been to expensive) and a quart of oil on 2 occasions. the temp gauge usually read at the middle mark (it used to run at the quarter mark) but never over heated until yesterday. fan and fuses are fine, no smoke from exhaust. the engine has been making a rattling noise for the past month but i dont notice a loss of power
thanks you
thanks you
Jul 2, 2009 at 9:47 PM
