1994 Chrysler LHS no running lights or dash lights
1994 CHRYSLER LHS
BACKHOE2391
Electrical problem
1994 Chrysler LHS 6 cyl Two Wheel Drive Automatic
i keep blowing the fuse for the dash lights and running lights. i changed the headlight switch but the fuse still blows after about 1 minute. where else should i look for the problem?
Mar 15, 2009 at 6:48 AM
  • 110,244 POSTS
Hi:
That is a good one. Check power supply to switch because if the circuit is open, power should should go no further. Unless this only happens with the lights on. IF that is the case, you need to start hunting down a short. It could be under the dash, wiring under the hood to the lights...
Mar 17, 2009 at 6:29 AM
